Coolant temp gauge 850t.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Thinking about installing a real engine temp gauge in my car but can't find much that details how-why that might be useful. Just had the head done (burnt valve and bad seals) and am paranoid about over heating this car. Ideas?
- AKJeeper
- Year and Model: 1996 850 Turbo Wagon
- Has thanked: 7 times
I can tell you that after having a ScanGauge in my '96 to give me the temp straight from the coolant sensor: the factory temperature gauge stays right in the middle at any "normal" temperature. I forget the exact range for 'middle', but it's something like 130*F-220*F. Not exactly usable in my opinion.
I was playing with the idea of installing boost, oil pressure and engine temperature gauges, too. My gripe was that I couldn't find any 850-specific gauge pods that would integrate nicely with the dash. I got the ScanGauge for the time being and used velcro on the ash tray lid to provide coolant temp information. Wish I could figure out a way for it to display boost.
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
A nice place to install gauges in any car are the glove box or the a pillar (if you have a spare a pillar panel and like to work with styrene) you can make that look really nice and as if it was supposed to be there.
I think someone on here fabricated a fantastic boost gauge in the a pillar.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
rguzz
What are the mechanics involved in installing a temp gauge? It does appear the Scan Gauge essentially requires no installation other than a place to plant it. Does it provide accurate engine temps? I know there is a video (RSPI) around with some details.
- AKJeeper
Aftermarket temp gauges usually need a few connections: dash illumination, temperature sender/sensor, and ignition power/ground. Some mechanical gauges utilize a sealed tube that will need to run into the engine compartment and tap into the water jacket (same spot you'd install a temp sensor for electronic gauges).
Mechanical gauges require less electrical connections (usually just dash illumination and ground).
- 12 Replies
- 2073 Views
Last post by regent
- 1383 Views
Last post by FLXC90
- 990 Views
Last post by rguzz
- 36 Replies
- 4774 Views
Last post by MoVolvos
- 383 Views
Last post by Roger_850T
