Ball Joint Torque
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
nisan17
Year and Model: 92 940 turbo
Has thanked: 2 times
Ball Joint Torque
Post by nisan17 »
Hi Group,
Does one know the ball loint torgue on a 79 242, 2.1 ltr. Please advise if there is any other specs and or advice I should know.
When I was doing my front brake job the ball joint job appeared to be very simple if all the bolts disassemble with ease!!! I noticed a lot of slop in one joint and then ordered the parts which came with no specs.
Thank You,
Kevin
Kevin
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Torque for the ball joint stud is 44 lb ft.
Torque for the attachment bolts is 15 - 20 lb ft. Use new bolts/nuts for this part.
Do not grease the ball stud as it may seat too deeply and damage the rubber boot.
Also be aware that from 1979 the left and right ball joints are not interchangeable. This may affect you - it depends when the car was actually built.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
nisan17
Post by nisan17 »
billofdurham wrote:Torque for the ball joint stud is 44 lb ft.
Bill.
Thanks Bill
I did notice the part #s on both boxes are the same...we'll see.
Kevin
