1998 V70 AWD Propeller Shaft
- flyingswede
- Year and Model: V70AWD 1998
Trying to remove propeller shaft, the back came out easy. The front NOT. I have tapped used WD-40, PB Blaster, no movement. Any idea's?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
All 6 screws out? Put it in gear and see if it breaks free.
- flyingswede
Yes all 6 screws are out. After many F bombs on the garage floor, it came out. Now to find parts to rebuild.
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
leave it out, better tire wear and mileage.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Don't forget torque steer, worse tracking and tire spin!1998v70xcbill wrote:leave it out, better tire wear and mileage.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Is this what you're looking for?
https://nwct.craigslist.org/pts/6040890783.html
Or this?
https://hudsonvalley.craigslist.org/pts/6000612302.html
I often look for Volvo parts and have never seen this stuff before... Is this the part that always goes bad on the XCs?
Or this?
Retired:
2015 Volvo S60, T5, 85K
- Has thanked: 2200 times
No he is looking at the prop-shaft that connects to this part which is the angle gear. It is basically a differential and turns the power from the transmission 90 degrees and to the prop-shaft to the rear wheels.
These are getting harder to find, and buying used is a crap shoot. You have to make sure it turns and that the collar (the shiny cylinder) is not stripped internally of its splines and also the splines on the shaft it connects to. If they splines on the shaft are toast then so is the unit. The collar is getting harder to find and is the weak link in these units. Prices are fair if they are good. It is not something I would buy unless I could touch it or get from a recognised good used part supplier.
- theWIFES_S70
Thanks, Neil. I had no idea. I had never seen pieces like this for sale on Craigslist around here before.scot850 wrote:No he is looking at the prop-shaft that connects to this part which is the angle gear. It is basically a differential and turns the power from the transmission 90 degrees and to the prop-shaft to the rear wheels.
I don't think I'd get an AWD. But seeing one up close, I can see why folks want to hold onto them. It's a shame about the parts though...
Retired:
