Volvo S70 1998 sputtered to a stop...
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
My daughter's S70 stalled today. Seems like it doesn't have fuel or spark. She said that she can hear the fuel pump running so I'm thinking the coil has failed. Has anyone ever had one fail while driving?
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
On our '97 855 GLT, we have experienced three stalls. One was caused by a failed fuel pump and two were caused by a sticking idle air control valve. The coil hasn't failed yet on ours at 192k miles.
- Has thanked: 1501 times
- Been thanked: 3812 times
More likely cap/rotor failure than coil, if she can hear fuel pump running ( good situational awareness by the way!)
- Has thanked: 304 times
- Been thanked: 517 times
Hmm... have her check the coil wire, that may be damaged. I've never heard of a coil failing like that on these cars.
Other than the cap/rotor, it could be sensor related. You would have to check for codes though.
- rspi
Contact rspi..
Good to know. It was the fuel pump. (Not sure what buzzing sound she was hearing in her head). SMH
We need to start a poll about how long a fuel pump last. Seems they are time/miles change items.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Your daughter probably heard the idle control motor. Fuel pumps are good to at least 180K, longer if the fuel filter gets changed once in a while. I hope she carries a good fuel pump relay in the glove box, along with a folding torx tool.
Klaus
I keep a spare relay in mine since I replaced it and it turned out to not be an issue. Might as well keep it in the car, you never know when it'll go out.Klausc wrote:Your daughter probably heard the idle control motor. Fuel pumps are good to at least 180K, longer if the fuel filter gets changed once in a while. I hope she carries a good fuel pump relay in the glove box, along with a folding torx tool.
- rspi
Contact rspi..
I believe she has a jump wire in there. Also has a relay.
