volvo xc90 2.9 auto t6 4 speed drain and replace transmision
andymac5
Year and Model: volvo xc90 t6 2.9 au
Post by andymac5 »
I had the message Transmission Service Urgent and Transmission needs service its an old car 93k miles on the clock.
Its the 4 speed auto 2.9 t6 awd.
I thought I may as well try the gear oil change as I had found 9 liters of Dexron 111 on ebay £41 pound.
I proceeded to remove protection tray from beneath the gradually removes all the 10mm bolts holding the sump on being careful not to damage the gasket of course i needed few containers to catch the old oil which was dark brown and should be red.
I then cleaned the sump cove that had grey sludge cleaned the inner parts i could see using tissue.
I then put it all back together and refilled using a funnel from the top easy to get too dip stick hole.
Ithen gave it a few runs and tests and to my amazement all faults cleared and now runs perfect.
lucky me .
its not a full flush
hope it works for you
happy days its great when things work
pics attatched
sump volvo 1.png (691.93 KiB) Viewed 1175 times
XC90 DIP STICK.jpg (265.05 KiB) Viewed 1175 times
car lube.jpg (18.85 KiB) Viewed 1175 times
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Good work :-) Thanks for joining and posting.
Also -> Amazon link
