Thanks to abscate meeting up with me to give me his extra PVC hoses, I got my car back on the road with new/cleaned out PCV system. Then the exhaust started leaking, so I fixed that and shortly after the CEL light went on. Also it seems the idling/shifting is off and the car is pinging a certain amount. This has been this way for two days. This morning when I went on a short errand, the car wouldn't start and I heard a ringing noise from the throttle body. I let the car sit for 30 second, then the ringing stopped and the car started. The codes that I am getting are:
P1119 Sensor/MAF sensor Adaption performance problem or signal out of range (upper limit)
P0171 System Too Lean (bank 1)
Any ideas of where to start?
Thanks,
Feld
2000 v70 codes from CEL
- Has thanked: 316 times
- Been thanked: 531 times
Sounds like your MAF sensor is either dirty or dead. You could try cleaning it with some CRC Mass Airflow Sensor Cleaner and see if that helps. Also check out the connector for the sensor and clean it off it it's dirty.
Just make sure you ONLY use MAF Sensor Cleaner to clean your MAF sensor. Anything else will damage it.
- Been thanked: 4071 times
Feld...that ETM should whine for about 10 seconds when the key goes to POS II (on, not started) and then whine should stop.
Thats all normal and good.
If we can connect sometime, we can check your Short Term fuel trim with my AUTEL and tell if you have vacuum leak or a fuel delivery problem causing your P0171.
P1119 is a new one to me - gotta think that one through.
DrJammer
- Year and Model: 2000 V70XC - 195k
- Has thanked: 1 time
I feel like I was chasing a P0171 near the J hose near the charcoal canister in rear on a 2000XC
changed out the fuel cap and it went away. I am not suggesting to throw money and guesses at a problem, just sharing an experience
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
- 19 Replies
- 3557 Views
Last post by Chapelgirl
- 2681 Views
- 4677 Views
- 2470 Views
Last post by erikv11
- 808 Views
Last post by matthew1
