2000 volvo v70 N/A coil pack coincidence
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Been thanked: 6 times
Post by famfeld »
After completing a compression test, my car began to run really rough. I figured out that number 4 coil pack was bad because when disconnected, there was no difference in the rough idle. So I got 2 from the salvage yard (1 for a spare). When I got back and installed the new coil pack on number 4. It still ran rough. I figured out that number 1 was now not working. I switched out number 1 and now it runs fine again. Is this just coincidence, or is there some other possible cause? I should mention that the check engine light came on earlier (a few days prior to the rough running problem) and I have the code for the MAF sensor reading out of limit and the oxygen sensor reading lean (bank ), codes p1119 and p0171. Any ideas? Enjoying the nice weather in the salvage yards at any rate.
Thanks,
-Feld
Has thanked: 1502 times
Been thanked: 3817 times
The often croak in packs, like lemmings. No reason for it but I've observed this across brands
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
If this is anything like the ones my 99 uses then check and double check you're getting a good ground. Each of these grounds to the head (under the bolt) I believe as well as the harness. Someone somewhere likely has a diagram you could use with a multi-meter to verify the continuity of the coil pack.
