I successfully removed my angle gear, but now there is a big oil leak. It drips pretty aggressively in three spots after I park the car. It is hitting the subframe and spreading out (it is definitely engine oil and not transmission oil). I am hoping I somehow disturbed the turbo oil return line and I just need to fix that. Does that sound right? The oil stops dripping after a few minutes and is dripping slightly to the driver side (but the leak could be anywhere since it is running off the subframe.
You do not want to know how much I dread crawling under the car again, lol. But the good thing is there is now plenty of room to work now that the BG is out. Does it sound like a turbo return leak? Any other things I should check while I am under there? I did move the oil cooler when taking the BG out, but that area is fine and the leak is not there. Thanks in advance.
Removed Bevel Gear but now oil leak...
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
With the angle gear out, working on the XC is SOOO much easier. You should have very simple access to the turbo return line. I think you're just gonna have to get under there and check it out. When I removed my angle gear though, I don't remember messing with the turbo at all.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
Thanks. You're right it's like a cavern in there without the BG. I was banging around with my wrenches getting the BG out, I'm thinking I may have knocked the return line and damaged the gasket. It's the original 17 year old one, so I'll see.
I have some tips and pictures of the removal that I will post. Things were not exactly as others have described and I came up with a really easy way to keep that collar in place that does not use Loctite.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
FlyingVolvo
Curious to see how you did it. I used the hose clamp method.
I have no idea how people used the loctite... there's no way it can hold through the vibration and force from the transmission and plus it's the ATF is all wet and does not help any bonding.
That's pretty impressive your turbo return seal is original. Most have failed by now at least once. Mine's on the first change, but not bad considering I'm nearly at 250K. That's a real PITA repair with the angle gear still in there.
2023 V60 T8 PE
2023 V60 T8 PE
- 18 Replies
- 3562 Views
Last post by Skymongrel
- 1123 Views
Last post by rmmagow
- 2894 Views
Last post by MoneyPitC70
- 2504 Views
Last post by cn90
- 3496 Views
Last post by mrscullini
