Do I really need this $30/liter angle gear oil, or would any good quality 75W-90 gear oil work just as well? Thanks
http://www.ipdusa.com/products/6721/114 ... e-gear-oil
The AWD is disconnected, but the angle gear is whining and it seems to be getting worse.
00 V70 XC SE Correct Bevel Gear Oil?
- Year and Model: Many Volvos
- Been thanked: 76 times
I used some Royal Purple GL5 that I had left over from filling my 5 speed but it was stupid expensive too. I think the Volvo stuff is synthetic so you should probably stick with something that is synthetic but really any gear lube should work.
Blockpartie
- Year and Model: ...
On paper you can use any oil you like as long as it matches the specifications. Personally I'd use OEM just to be save.
A whining angle gear is close to become a failing angle gear. Changing the oil will not make the noise go away at this stage.
pedal2metal
- Year and Model: 1998 V70xc
I just put Lucas Oil synth. 75w/90 (from Advance $17 for the bottle) in my '98xc. It appeared to be of high quality... but then again most are nowadays.
'98 V70xc, '03 gti 1.8t, '99 F150, '90 Corrado, '80 Scirocco
- 2903 Views
Last post by MoneyPitC70
- 3503 Views
Last post by mrscullini
- 1229 Views
Last post by FlyingVolvo
- 1425 Views
- 2086 Views
Last post by Bamseclub
