Brown Volvo 2001 XC70
Normally, I set the fan on the third or the fourth green LED
for 'good' temperature and 'enough' air flow.
Red Volvo 2001 XC70
- At the third or fourth green LED, the noise at the heat core is as louder
than the brown Volvo at full blast.
- At full blast, the air flow is as low as the brown Volvo at second LED.
So it looks like the red Volvo is working much harder to produce air flow and temperature.
Fan Speed And Air Flow
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Also, there may be a flap door that doesn't open properly- broken hinge, burnt motor or simply a CCM calibration
- Has thanked: 1502 times
- Been thanked: 3817 times
There are also two different air filters for the P2 cars, thick and thin.
The ECC control unit will give different flows depending on how it is programmed, too.
Jim commented here when I replaced my filter
viewtopic.php?f=9&t=70538&hilit=2005+ca ... 0&start=10
Oka
The gotcha here is the word 'filter'. Then it clicked it did not come to mind.
Started driving the care a few months ago. Very logical to think about my issues could be a result of the "working much harder" scenario to relate to the filter. As soon as I could, I went to the car just to take a pick underneath the glove compartment. Was shocked! First, the panel underneath the filter housing was missing. Found the panel inside the box the previous owner had given me.
Looking closer, I found the filter housing cover was half way opened I could see the filter. I supposed to have four screws. The first two were completely missing. The other two further back has the left one almost half way out; the obvious reason I mentioned "the noise at the heater core is louder . . .".
There are more. The filter housing has two compartments. Shouldn't the filter be in the first compartment, the one closest to you? This filter was in the further compartment. When I removed it, saw lots of debris clogging the filter. Dirt was literally falling out of the compartment while I was trying to pull it out. I managed to remove it, vacuumed the compartment, put the cover back just to test it. Wow, at the second/third LED fan speed setting, the air was just gushing through the dash vents, of course without a filter.
Really appreciate everyone's input on some possibilities.
The two slots are explained inthe thread above...P2s have a choice of filter
- 6216 Views
Last post by xHeart
- 1785 Views
Last post by alschnertz
