06 XC70_Crank No Start
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
elgringodk1
Year and Model: 2005 XC70
Post by elgringodk1 »
I'm a newb to this forum and I've searched the web for my issue, so I'm hoping someone one here can point me in the right direction.
Problem: 06 XC70 - intermittent crank but no start.
My wife's 06 has a couple times now on hot days, after having been driven for a while and then stopped to get gas or run into the store, not been able to be restarted. It will crank but not start. Fuel pressure on the rail and fuses check out. From what I could tell the grounds are all good. I'm thinking it's a wiring issue or maybe a temp issue. In all cases it's happened, I can let it sit for an hour or so and then it will start no issues. Also, it has only happened 3 times now and we've had a lot of hot days, so I'm guessing a temp sensor is going bad or I have wiring on the verge of failure.
Could it be the fan to the ECM and TCM that's going bad?
Has anyone seen this? My 03 XC70 has not had this issue at all.
Thanks,
DK
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Been thanked: 4 times
Post by Botbasher »
Yeah... the HOT days are neigh!!! My DIM decided to start scrolling hieroglyphics intermittently with the first of the 90F days here in NC!!
Could be heat soaking one of the modules and causing issues. I presume you do not have VIDA/DICE to be able to read it when it fails? Are there any error warnings in the text window? Can you pull up the simple DTC reader (in the text display) and see if any DTCs are set?
You're going to be getting a lot of WAGs without some data to base those guesses off. Might try the XeMODeX Hair Drier trick and see if any issues can be made to happen on cue by heating the various modules. Heat seems to be the common fault.
Good Luck!
K "melting" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
Has thanked: 1506 times
Been thanked: 3822 times
When you have a no start, diagnose ignition from fuel problems first.
The P2s have had some issues with the fuel delivery (module that controls fuel pump, pressure sensor) so perhaps looking at the rail fuel pressure when it will not start will be a good place to commence.
