What brand, if any oil additive do you use?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
I notice my Volvo dealer as well as my sister's Ford dealer is pushing this BG oil additive MOA in their oil changes. My Volvo owners manual have said use no additives in the oil. Yet I looked at my last change invoice and MOA was put in my engine again. I noticed in the past MOA causes the oil to become dark in fewer miles than just synthetic oil alone. My engine sounds normal and is running as smooth as glass like always.
Does anyone know anything about oil additive like MOA? Are additives good for engines? Or do they just end up clogging up the filter?
I would like to know if any of you mechanics out there recommend or use certain additives like MOA, STP, or whatever brand in Volvo engines. What do you use in your Volvo? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
June wrote: 02 Jul 2017, 17:35mechanics out there recommend or use certain additives
If it ain't broke, don't fix it.
When an OEM suggests to change oil/filter in a gazillion miles, do it in 1/2 gazillion miles.
People who change oil/filter before their suggested time, will have engines that last longer. As engines get older, more blow-by exists, so change intervals need to be increased.
When oil consumption goes up, STP® oil treatment may reduce consumption. Or find a cleaner that is poured into each cylinder, and then removed....assuming rings sticking on pistons.
Oil companies today have some fine oils....engines will last a long time on them, if oil/filter is changed, over and over, before OEMs' suggested change interval.
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
"Or find a cleaner that is poured into each cylinder, and then removed....assuming rings sticking on pistons."
What kind of cleaner would this be?
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Restore was the go to years ago when they were in cans. Haven't use them for sometime.
https://shop.advanceautoparts.com/p/res ... es+restore
This is the go to for problematic engines - Smoke, oil consumption, lifter noise...
Swepco 502 Premium
Engine Oil Improver
Oil Additive
https://www.pelicanparts.com/More_Info/ ... mReviewAnc
https://www.swepcolube.com/products/swe ... -improver/
Recently found some at a great price $7.50 vs $12.20 so started back but just one bottle with each oil change for a additive package boost. I think I got the last of Paragon's 5W-30 inventory :lol: .
SWEPCO 306 Supreme Formula Engine Oil
https://www.paragon-products.com/Swepco ... /sw306.htm
306 5W-30.png (38.48 KiB) Viewed 1179 times
June
Post by June »
The Lucas zinc additive quieted my 1991 740 Turbo camshaft after a few hundred miles. It was ticking loudly. I plan on adding to every oil change. June
My Volvo cars owned
1996 960 ordered
MoVolvos
Post by MoVolvos »
Swepco + on ZDDP and Boron. Used it in my 98 S70 T5 then one winter got a little thick then went with 308 5W-40. Besides the recent 303 10W-30 purchase as a booster to oil changes I forgot I have another depending what I think the car may need at the time.
https://bobistheoilguy.com/forums/threa ... oa.352076/
https://bobistheoilguy.com/forums/threads/swepco.72487/
