Loud Noise Under Hood may be Loose Alternator Pulley Bolt
ALF1
- Year and Model: XC90 2003 2.5
- Been thanked: 5 times
At 210,000 miles on my 2003 XC90 2.5T AWD, I noticed a slowly growing noise / growl under the hood that I just could not identify. Eventually it became loud but unidentifiable. After a 600 mile trip it got very loud but nothing seemed amiss. Serpentine looked fine. Low mileage on the timing belt. Finally, while watched the engine run, I noticed that the pulley on the alternator shaft was occassionaly drifting axially in and out almost a half inch. I didn't realize that the pulley is bolted onto the shaft because the end of the pulley is covered with a thin black plastic cover and appears to be pressed on. I nursed the car home...too late...the pulley fell off as did the serpentine belt. Drove on battery until it went dead and then a tow. On inspection, I noticed that the end of the alternator shaft is threaded inside and out. The outside threads had been ground off....obviously the source of the loud noise. Yes, I replaced it with a reman alternator that came with an installed pulley. I also replaced the serpentine belt as it experienced grind points when the pulley came off. All is fine. No more loud noise, no more growl.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
good info thanks!
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 3999 Views
Last post by ALF1
- 605 Views
Last post by Tracee
- 753 Views
Last post by RickHaleParker
- 18 Replies
- 1184 Views
Last post by paul1149
- 15 Replies
- 9920 Views
Last post by alexv702003
