I figured I'd start a new thread since I completed the PCV replacement and cleaned the ETM over the weekend. This is not my daily driver yet, so when I got home from work tonight to fire it up since finishing last night it turns over fine and seems to want to start but just won't do it. I've connected everything back the way it was and checked vacuum hoses and it's all good but it just won't start. I checked the fuel rail and it's full and pressurized and I guess I will have to check for spark tomorrow night but is there anything that I could've accidentally done to cause this? Well, I'm sure there is but anything that has happened to others that could be likely?
thanks,
2002 V70 XC Turbo-replaced PCV system-now won't start Topic is solved
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- Been thanked: 4064 times
It is easy to misalign the intake manifold gasket causing a no start.
Double check all the vacuum hoses.
Mine took a but of cranking to fire up after the job, maybe a little but of starting fluid will give it a boost from an empty manifold.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Huge vacuum leak or you cleaned the ETM a little too well. Does the ETM still have the 8sec whine with ignition in PosII ?
aaron1611
I haven't gotten back to the house yet but I'm thinking my mistake was when I removed the ETM I didn't replace that gasket, forgot to order it ahead of time and my indie shop was closed. I'm thinking I'm getting unmetered air in and that's why it won't start. I've reused gaskets in the past with no issues but could this be the problem?? I thoroughly cleaned all surfaces before installing the old gasket but it looks like I'm going to have to get back in there. Sux.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
ETM has the 8 second whine.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
well now I don't feel like such an idiot. Sprayed a little bit of starting fluid and it started right up and idles nicely. Problem is that I'm still getting the reduced engine performance command when I go to accelerate, just as before. I'm going to do an oil and filter change this weekend and take it for a longer drive but should I still replace the gasket? I already bought it online so I guess it can't hurt. I guess back to square one on this.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
precopster
The codes will tell all hopefully. You need to read the car with a diagnostic scanner.
Used the same ETM gasket about 10 times on my T5 and about 150 times on my 2000 V70 (non turbo) as I provide an ETM changeover service and use my cars to test ETMs
Unless you can see a hole in the gasket I wouldn't bother with it.
Mine took about 30 seconds of cranking to restart after the PCV job, that surprised me.
Get a look at th e short term fuel trims to diagnose a leak or smoke test it.
Page 2 of this thread describes how to test this.
viewtopic.php?f=1&t=79374&p=428689&hili ... im#p428689
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Are you purging the air out of the fuel line/rail before trying to start it? I've had everything disconnected that one would for PCV service at one point or another and it always took right off like nothing ever happened.abscate wrote: 25 Jul 2017, 19:12 Mine took about 30 seconds of cranking to restart after the PCV job, that surprised me.
- 618 Views
Last post by 2002VolvoC70
- 1145 Views
Last post by MadeInJapan
- 1446 Views
Last post by ricebw2
- 12 Replies
- 2413 Views
- 1953 Views
Last post by MVM17
