the serpentine belt shredded and wrapped around the alternator in my 1999 volvo v70 AWD ..had to cut it loose...two other pieces where stuck in two different spots-pulled them out
replaced the belt now it will crank but not start up...acts like it's flooding itself(strong gas smell). what is the solution to make it start running? would appreciate any advice....thank you in advance
1999 volvo v70 awd replaced shredded serpentine belt now won't start
samanthasmith1967
- Year and Model: 1999 v70 awd
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Does it sound like its cranking faster than normal? Its possible this is just an example of lawn mower syndrome. Remove each spark plug and add a spoonful of oil to each cylinder and try again.
Lawn mower syndrome leads to excess fuel washing away oil around the cylinder reducing compression; adding a spoonful of oil helps restore it.
- Year and Model: Many Volvos
- Been thanked: 76 times
Pop the timing belt cover off and make real sure that the serpentine belt shrapnel didn't sneak its way back in around the sprocket on the harmonic balancer. It has happened before and with disastrous results a few times. If everything looks good there then start checking sensor wires that are in the area around the front of the motor like the ECT sensor and the wire harness that runs to the ECU.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Try and rotate crankshaft manually clockwise 360 degrees by hand Like you would after replacing a timng belt. Or do a compression test. As Lee commented... others including me have had that belt break wrap in the crank shaft area and it caused the car to skip time and bend valve stems.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Been thanked: 35 times
Have you pulled the engine codes?
- 1296 Views
Last post by oragex
- 20 Replies
- 5297 Views
- 719 Views
Last post by RickHaleParker
- 930 Views
Last post by misha
- 16 Replies
- 2989 Views
Last post by DanelleNavarro
