2004 XC70 rear wheel bearing.
I have replaced a couple of bearings in my time, but it has been a few years. I just bought one off of ebay and it's not as smooth as I think it should be. It has a tight spot in it but it is certainly not "stuck." A car's weight will probably not notice it, but before I remove the problem bearing, should I be concerned about this?
How "smooth" should a wheel bearing be before installation?
If it is a sealed roller bearing don't install it. You shouldn't feel any sticky spots in such a bearing.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The very first thing is make sure to get an original Volvo one, not sure how they are stamped, but even when it comes off a Volvo the owner might have already replaced it with some cheap aftermarket part.
As for the way you describe, my interpretation is obviously entirely subjective so I assume you feel a resistance say of 6 on a scale 1 to 10. That would be too much for my taste. I got a used one that also had a 'tight' spot but it was not a big deal perhaps a 3 out of 10. Other than that spot it is very smooth. Btw, a good 3 arms puller is basically a must for this job.
- sanfelice
- Year and Model: 00 VR;04 XC70;97 965
Yes, oragex, I think you have it right, about a 6 out of a 10. I will be returning it and buying new (this one was nearly new, but was probably defective to begin with, B stock, so to speak)
- SuperHerman
- Been thanked: 207 times
I bought four ebay hubs from some eBay seller "Detroit" something for my old V50. One bearing failed after 500 miles. Pure junk. Never again.
Buy a quality brand if you don't buy OEM. SKF makes replacement hubs - they are quality.
I've done three Volvo hubs now that we're growlers..none of the old parts felt different than new
The bearings are expensive but they are built to last, I drove my growlers for at least 10k before replacing
precopster
- Year and Model: Lots
- Been thanked: 128 times
I feel guilty now. I put in a $55 GMB from Amazon on my 2006 XC90 recently and these cars are heavy and known to go through them. I hope it lasts.
- sanfelice
Yeah, don't know how long this car has to live, given the other problems it has at the moment. So... don't want to plop down $$$ for a bearing. But that whoomp whoomp whoomp is making me crazy!
If you go the wrong way around the rotary it will be quieter, half of Boston drivers won't noticesanfelice wrote: 28 Jul 2017, 18:54 Yeah, don't know how long this car has to live, given the other problems it has at the moment. So... don't want to plop down $$$ for a bearing. But that whoomp whoomp whoomp is making me crazy!
- 1151 Views
Last post by SuperHerman
- 1371 Views
Last post by matthew1
- 2569 Views
Last post by songzunhuang
- 1469 Views
Last post by bmdubya1198
- 236 Views
Last post by Clemens
