MAF sensor changed but car still have no power when driving it.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Does the car have 2 o2 sensors or just one?
Where is the hole in the exhaust....before front o2 sensor or between 2 of them(if there is one after a cat)?
Check for vacuum leaks....they kill performance on turbo cars.
Check the fuel pressure regulator and fuel pressure.
Check ribbed hose from maf to intake.
Spark plugs MUST be irridium ones for T5 or oem Volvo ones...or cheap copper ones BUT properly gapped because gap is CRITICAL on these.
Did a replacement MAF had the same BOSCH # number like old one?
What is the condition of turbo?
Make sure that intercooler doesn't have a hole in it somewhere.
Are there any codes....is check engine light on?
On '95 you can read them yourself from ports under the hood.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
All Volvo turbos have intercoolers, they cool the intake air. If the intercooler has a hole in it, it has to be replaced. This can be because a rock hit it - the intercooler is in front of the radiator and AC condenser and is visible behind the front grill.
Usually, the intercooler piping in the engine bay gets loosened by a mechanic and the same lack of power exists. Lift the bonnet and check all of the large black tubing connections. Using a rag, grab an air tube and try to twist it. If the tubing moves even a little bit, tighten the clamp with a screwdriver.
Klaus
