04 XC70 195k miles
On the way home the other day and suddenly started skipping. Managed to get it home, pulled codes and got P0300, P0304, P0302. Switched some coils around to see if it was bad coils, made no difference but when I drive it and then clear codes it gives random cylinder misfires, could be 2 and 4 or 1 and 3, etc. in addition to the P0300 multiple misfire. I have checked wiring around the coils and injectors, there certainly isn't anything obvious. Any ideas on where to start?
04 XC70 Multiple misfire
- Has thanked: 1613 times
- Been thanked: 4078 times
Misfires are either plugs or coils 99.9% of the time.
Plugs will look good even when they are old and overgapped. Replace if they are over 30k miles old
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Too bad you didn't note and clear the initial codes then resume driving the car to see if the same ones would return.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I'd say something else is triggering it.
I've had multiple coil code misfires that were unrelated to the coils.
I had previously checked fuses and put a couple back in the wrong slots. (in the engine bay).
Once I figgered that out the coils all cleared up.
Nother time I burned the fuse that runs the eBox cooling fan and that started setting codes all over the place with reduced engine performance warning. eBox contains the engine computer.
got Vida ?
got Vida ?
I haven't looked at any fuses. The only codes I have had are the misfire codes. Since it first happened the other day, it is constantly misfiring in one or more cylinders. There are no moments of it firing on all cylinders if you know what I mean.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- jonesg
NO, a bad coil can be traced by swapping it and seeing of the misfire follows the coil.
Where is Maine are you? I'm moving to Island Falls in 10 days.
You need to get a vida scan done.
- 19 Replies
- 10374 Views
Last post by Barledge
- 1301 Views
Last post by movingim77
- 1292 Views
- 338 Views
Last post by aaronlife
- 13 Replies
- 5103 Views
Last post by draser
