Hello folks........is it normal for the steering wheel/column/brake pedal assembly to vibrate when going over bumpy roads? koz not only can i FEEL the vibrations but i can see my steering wheel shake up and down...
was wondering is this an inherent build quality trait of all 850's or is it something else?
its not a major problem but its just a little tiring when going long distance....
p.s. i've replaced all engine mounts..........am i missing something else whioch needs replacing?
Volvo 850 Build Quality
- Has thanked: 2864 times
- Been thanked: 1332 times
I'd attribute steering wheel shake to poor chassis rigidity. A few posts back someone spoke about this, and challenged anyone to park their 850 with one wheel on the curb, then try to open a door.
It's too bad because a flexy frame affects other things besides bumps like handling, and the 850 is pretty good in most other areas.
I believe a strut brace helps offset this weakness.
- 1705 Views
Last post by erikasambrozas
- 4015 Views
Last post by bigsi15
- 24 Replies
- 6539 Views
- 3174 Views
Last post by melissajam
- 710 Views
