06 S60 w/ Reverse issues
s_watts
Year and Model: 2006 S60
Post by s_watts »
Hello All,
This might be a difficult one to identify the issue, but I am at a loss.
Over the last couple days
When I first start the car and drive a mile, it seemed as if something was stuck in the suspension and then freed. I found lots of reports of rocks getting stuck between the backer plates, that seemed to be the issue, it took care of itself. I cannot find any indicators fo that now.
Then a couple of times I put the car in reverse and backup a foot, there was a screeching (metal interference) noise. Put the car in park and tried again and no problems
Today, I tried driving in reverse. The first couple of times it was like the brakes were applied and it hit a dead stop. Did not give it a lot of gas. I put it in drive and then tried again no issues. After I drove it a bit, no more problems. I could fly around the block in reverse.
A bit of history on the car. Last month had front struts, outer tie rod, serpetine belt, timing belt, etc at a volvo specialist. Also did a transmission flush a couple of months ago. I have had no issues (do not think it was ever done before) and the car has since never shifted smoother. I was very careful to get the right amount of fluid and check the level regularly.
Any input would be appreciated. I am hesitant to take the car to the expensive repair shop again until I can give them a better idea what the issue might be.
Thanks,
Brian
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Parking brakes within the rear disc centre may have become loose or guide pins released. It's a drum brake within the rear disc.
Is parking brake well adjusted?
I don't think it's transmission trouble. Let us know what you find.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
am mentioned, have removed the rear drums and check/replace the br shoes inside. do asap before it causes more damage
s_watts
Post by s_watts »
Ill give it a try this afternoon
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
If it locks up while you're at speed the support built into the spindle/hub can break off, circled in red.
This happened to a PO on mine and was like this when I bought it. If this happens you won't be able to repair the parking brake without replacing the spindle. The brake cable can get pulled in and chewed up as the whole parking brake assembly effectively breaks free and rotates around the hub. The splash guard gets chewed up as well.
Has thanked: 1609 times
Been thanked: 4065 times
I once drove a car home 10 miles in reverse when it got stuck. I debated which lane to drive in for much too long.
The stupid things of youth.
s_watts
Post by s_watts »
Well I got it apart and found the brake shoe pad to be broken off. Glad I took it apart when I did. Thanks for the help!
mrbrian200
The pad material separating from the shoe was a problem with the OE parking brake shoes on 2000s Volvos. I don't know if issues with either the adhesive or the shoe metallurgy were ever corrected and whether replacement shoes from Volvo are likely to do the same thing again. Some were seen to fall apart after just a couple years when the vehicles were still almost new. If it were me I'd be wary of all the euro sourced parking brake shoes and go with a quality domestic aftermarket brand. The Wagner Thermoquiet line looks to be the main option. I've never ever had a problem with their brake pads/shoes/etc.
