Power Steering Problem
Cope6k
Year and Model: 2004 XC70
Post by Cope6k »
When turning either direction the power steering is stiff then jerks a little then stiff then jerks a little all the way to the stops. I replaced the pump, serpentine belt and checked the fuse and the problem remains. There are no leaks anywhere.
Any ideas? Maybe the rack is bad? Is there a filter screen in the reservoir? Steering shaft binding? Any thoughts are much appreciated
Thanks.
Jim
2004 XC70
150,000 miles
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Have you tried flushing and filling the P/S system with fresh Pentosin fluid?
Also, I found on my wife's 05 S80 that I need to fill the reservoir slightly above the full mark or else the system will suck air particularly when turning hard left and the fluid sloshes to the right exposing the pump feed port. When I flushed it the other day I was surprised at the flow rate.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
chrism wrote: 17 Oct 2017, 22:46 Have you tried flushing and filling the P/S system with fresh Pentosin fluid?
+1
If you aren't using the "green" PS fluid (Pentosin), you will have a problem. If the fluid is original, with that many miles and years of service, you will have a problem.
Good luck. Changing fluid is a relatively inexpensive fix.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
On top of the above there is a steering column coupler - the lower one in the engine bay - that likes to seize. Can be checked by disconnecting the steering column above the pedals - 14mm bolt, removing the rubber boot at the floor (replace the small bearing inside while there), then shackign the coupler by hand.
The reservoirs also had a problem with a piece breaking loose inside
dcm0123
Year and Model: S80 2000
Post by dcm0123 »
I also had problems with the coupler. Spray with WD40 to see if it helps. If it does, you know for sure what the problem is. Replace it because it will happen again very soon. Not hard to replace. Couple of hours work.
