Hello Folks,
Help please!
I have had my '09 XC90 since 2015, without any issues but recently the air con has started to behave erratically.
There are variable delays in the air-con working, and these are between a couple of minutes to over 20 minutes, and on some journeys the air con does not work at all.
I live in the Middle East and we have just had summer, so the air con has been working very hard in the build-up to (and during) this issue.
Despite a recent gas-recharge, when the air-con does work, it seems a little less powerful then normal and not quite so cold.
Would really appreciate any advice the community can offer.
Thanks
Chris
XC90 Air Con - Variable delays in start-up after Engine 'on'
ChrisDav1s
- Year and Model: 2009 XC90
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Not sure if these post (and fixes) reflect any of the symptoms you’re reporting or not:
http://forums.swedespeed.com/showthread ... -A-C-Delay
http://forums.swedespeed.com/showthread ... e-readings
Possible culprit might be the compressor solenoid valve if not the compressor itself.
