Proparts fuel pump noisy
AlanKot
Year and Model: 1998
Has thanked: 1 time
Post by AlanKot »
Hi guys,
So I replaced my fuel pump assembly on my 1998 V70R. What a mess... anyway after finally installing it and closing the flap I drove the car and the pump is so noisy. It’s almost unbearable! Any suggestions? Are those usually that loud?
Thanks
Alan
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Check and make sure it isn't bottoming out in the tank - the strainer shouldn't touch the tank from my understanding.
Check and/or replace your fuel filter - it may be restricting flow beyond what it should be.
AlanKot
Has thanked: 1 time
Post by AlanKot »
I just realized something. The high pressure line was put back on without the plastic insert at the quick connect part. There are no leaks but I wonder if that’s somehow causing it?
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Cheap parts for Volvo is just that, cheap parts.
I used DeatschWerks DW200 pump for my Volvo, they may not be direct fit, the fuel pump is quiet, has 3 year no fault warranty, and I can buy them directly from the manufacturer had me sold.
http://www.deatschwerks.com/products/fuel-pumps
85 GLH, 367 whp
00 Insight, 72 mpg
