'99 s70 performance tips
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
sasquatch666
Post by sasquatch666 »
what would be some good ideas to get as far as performance and the like. i tihkn i have the GLT model with 190 hp and 199 torque. i was looking into getting a chip first. any response would be great guys. thanks.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
before you buy any performance parts, make sure you've done "Stage 0".
Plugs
cap/rotor
oil/transflush
filter (oil)
hoses (the little vac lines)
samco hose kit
02 sensors
fuel pumps
clean injectors
clean IC/IC plumbing
Air filter
plug wires
Also -> Amazon link
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Matthew, let me add pcv maitenance to that list. At least have it done by 100K mile. If you're over that and don't know if it's done or not, you should just go ahead and do it. www.fcpgroton.com sells a kit for under $150 with all the parts you need. You'll also need a intake manifold gasket besides the kit.
