Hard starting & hesitating to shift
ranger481vs
Year and Model: 2007
Post by ranger481vs »
I just replaced my alternator on my 2007 XC90 3.2
The alternator seems to be working fine, however, the car now hesitates to start And hesitates to shift, as well. Did not have this issue before replacing the alternator, so not sure what I might have done, but concerned about some of the electrical connectors that I had to remove and reinstall, which was a pain in the butt. I replaced the map sensor, which was damaged upon removal.
I just checked the codes, and crank position sensor shows up. Wondering if, in fact, this is the problem, but seems kind of strange coincidence directly after replacing the alternator. Certainly no expert, but welcome opinions before I go ahead and replace the sensor. Thanks much! Matt
ranger481vs
Update. I’m going to go ahead and replace the crankshaft position sensor since it’s a cheap part. Does anyone know if this is something that the dealer needs to reprogram or reset? Or is it just a thing that the car will relearn on it’s own?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Dont think it needs reprogramming but Id first check the wiring and connection to the sensor. I'd also try first a used sensor, not worth spending full price when you don't know for sure. I'd also look closer at any ground wires in the area, wires at the alternator, proper routing of the belt, ultimately the alternator regulator may not be the correct one for the car. In case you still have the old alternator just don't throw the regulator.
ranger481vs
Thank you. The wiring for connector that plugs into the sensor looked a little sketchy. So, I redid that along with replacing the sensor ($20) eBay. All is well now, no more codes, and drives perfectly. Phew!
