Cluster color
Hey, going to change my cluster light cause it´s really not a color i like at the moment. I was thinking about either blue or white. What do you guys think? I found tons off cars with blue but none with white, so no idea how that would look
- Has thanked: 2215 times
- Been thanked: 1853 times
You can now buy LED bulbs to replace the originals and get many different colors. Check on Ebay/Amazon.
Ah nice, not sure if i should go with white or blue led tho :/ Want my car cleanscot850 wrote: 19 Dec 2017, 15:39 You can now buy LED bulbs to replace the originals and get many different colors. Check on Ebay/Amazon.
You may find the white too bright even reducing the light intensity, that is probably why the bulbs have a yellowish tint.
Blue may work but may not be bright enough.
Trying it may be the only way to go, but I know there was a thread on this recently where someone used LED bulbs for the dash lights and posted pictures.
Here is a how-to on VolvoSpeed:
http://volvospeed.com/vs_forum/topic/10 ... of-my-car/
https://www.ipdusa.com/products/8884/12 ... nation-kit
Here is a 940 with white LEDs:
https://volvoforums.com/forum/volvo-240 ... hts-87654/
IPD installation video:
Thanksscot850 wrote: 19 Dec 2017, 16:20 You may find the white too bright even reducing the light intensity, that is probably why the bulbs have a yellowish tint.
TWC
- Year and Model: 95 850 2.5-10V LW
- Has thanked: 2 times
By accident, I found out that replacing the factory bulbs of the climate control with cold white LED is resulting in a blue light (due to the green tinted plastic light guide, I think). Need to replace them one day whith warm white LED, since I prefer green light for the interior gauges and controls.
That could also be a problem for you with your plans of changing to white, since you would likely have to remove the light guides. Another option might be plasma gauge discs, seen them on ebay.
- TorslandaWreckingCrew -
- 11 Replies
- 4468 Views
Last post by Faheyk1981
- 5209 Views
Last post by oragex
- 1528 Views
Last post by MDK
- 793 Views
Last post by brando_calrissian
- 681 Views
Last post by britishrocco
