2001 V70T5 DSTC Service Required - Engine Stall/Limp Mode
perkinsfmly
Post by perkinsfmly »
I've had progressively increasing symptoms over the last couple months on my 2001 Volvo V70 T5 / 150k miles.
- Started out with a DSTC Service Required message and the car starting for about 3 seconds and then dying. Then it would crank, but would not start for a couple days. This happened 5-6 times over the course of about 3 months.
- Now while the car is running the DSTC Service Required message and the DSTC trouble light will come on and the car seems to go into a Limp Mode -- one gear available (2nd?). When I turn the engine off and back on the DSTC Service Required will go out, but shortly thereafter come back on.
- This has gotten progressively worse. I left the car with the Volvo dealership for 3 weeks and they were unable to get the car to duplicate the original behavior. Guess I'll have to bring it back to the dealership...
- Anyone have any idea what the problem could be?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
perkinsfmly wrote: 24 Dec 2017, 14:23 Guess I'll have to bring it back to the dealership...
Did they pull any codes?
Has thanked: 1610 times
Been thanked: 4067 times
Your 2001 uses a first generation electronic throttle body which has a life of roughly 150k miles , but if it fails it should store codes in the ECU. You will have to have codes read in limp mode to confirm.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above, at least ask them what were the codes.
A thing about the dealership. Saying 'we didn't find anything' may well mean they are not sure what the problem is and don't want to make you pay thousands for a new throttle body or some computer then have the car still doing the same thing. In some way, they are being honest because most dealerships will joyfully make you pay thousands with no results and no refund.
Go slowly when diagnosing this issue, the worst is to let a mechanic replace parts to see if it works.
Is your car the cross country awd model by chance?
perkinsfmly
1.5 years and I'm still struggling with this same problem. 2001 Volvo V70 periodically gets a DSTC Service Required message and will not start (cranks, but won't start). Sometimes when I'm driving the car the message will come on and the car goes into limp mode.
I've had it at the dealer twice for about 2-3 weeks each time. They tell me they can't get it to repeat the problem and they're not reading any codes. In fact, the dealer tells me the VIDA system won't even read codes connected with this problem. (Maybe I need to find another dealer.) I took the car to an independent European auto repair shop that specializes in Volvos. They said they did find codes -- didn't quote me the exact code, but said it indicated communication faults between maybe the ECM and SEM? Suggestion from this shop was to reload software in both computers (~$400) which might work. If not, they would replace wiring harness (~$600) which might work. Then they said replace both computers...lots of $$$.
I think I'm about ready to get rid of this car. I hate to buy a new car, but I simply can't rely on this one and having it sit around in my driveway is doing me no good.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Has anybody tried unlocking the ECM and TCM, cleaning the contacts and re-installing? Both the dealer and the independent should have the lock/unlock tool.
Xmodex will rebuild the CEM for about $500 , Henry can clone your ECM for about $200 ( user doublebug here)
That shop wasn't too helpful giving generic info, you need the actual codes.
Maybe we've got a member nearby with VIDA who can help you get this put right?
perkinsfmly
I got a code reader that will see the Volvo codes. I'm getting the following: CEM-1A5D, CEM-1A62, CEM-1C01
Those are the stored codes. Right now the car is starting/running fine. But I will eventually get a DSTC Service Required message and a crank/no start.
deano1
Year and Model: 2001 s60 1999 awd
Has thanked: 13 times
Been thanked: 17 times
Post by deano1 »
My newly acquired 2001 V70 T5 is showing "DSTC service required" in the message box but the car runs and drives fine.
Maybe I should mention the PO recently installed new ETM.
I used my Autel to pull codes today and A002 or something about "side accelerator" fault. I cleared it but it came back with the first key cycle.
Any ideas?
Stay curious my friends
DSTC uses both braking and the electronic throttle body to limit power to the wheels for both traction and slip control
An intermittent service message is probably either wiring or the module.
Don’t trust the AUTEL translated codes, read off the real ones and then use either VIDA OR the web to translate
