As you all know, courtesy lights go on as soon as you unlock yours doors (remote control) or open a door and they go off automatically after a couple of minutes thanks to a built in timer relay unless you start the engine which cause the lights to go off straight away.
My problem is that even if I start the engine the lights still wait for the timer to put them off.
Any idea of what could cause this problem?
Thanks in advance to you all.
850 courtesy light timer
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Could be the relay - #11 on the central electrical unit.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
mistercrunch
- Year and Model:
Hi,
A bit of an old post I know, but only joined yesterday. Fantastic site by the way!
My '96 850 GLT has the exact opposite problem: the courtesy lights don't work. I can switch them on manually with the ceiling switches, but when the main switch in set to "door" they don't work at all. It's not the microswitches in the door, because the footwell lights do come on. According to the circuit diagram in Haynes, these are independent of the ceiling courtesy lights.
I suspect the relay, but I have no way of testing this. Also, before breaking completely, the lights were intermittent, sometimes working sometimes not. I read somewhere that someone replaced the caps on the fuel line relay after a similar intermittent fault; could I do this on the lighting relay?
Thanks, Pieter
Thanks, Pieter
- Year and Model: Many Volvos
- Been thanked: 75 times
It can't hurt anything to try. Make sure that you get the polarity on the caps right.I read somewhere that someone replaced the caps on the fuel line relay after a similar intermittent fault; could I do this on the lighting relay?
- 857 Views
Last post by jreed
- 3288 Views
Last post by Blockpartie
