My 850, 2.4L, 10V, NA,1995 hasn't got a central rear "stop" light. That was the very last model (in Europe) not having it.
I intend to install one but wonder about the electrical connection.
Should I just connect it to one of the other stop light (+) or should I connect it to both (+) as I believe connecting to one of the two only might affect the "blown bulb" detection system.
Any feedback or (simple) wiring diagram will be much appreciated.
Dan
850 third (central) rear stop light
bobsnow100
- Year and Model:
No, I would just connect it to one stop light and see if it works. I would not connect it to both,one connection would do it, I am not sure if your bulb out light function will be upset though
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I put a third stop light on a 740 some years ago and wired it to only one of the other stop lights. The bulb out light came on. Apparently it was designed to work with an even number of bulbs. An auto-electrician advised wiring it from the stop light switch on the brake pedal, which I did. I do not know if wiring to both stop lights would overcome the problem.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 13 Replies
- 5314 Views
Last post by S40volvo2007
- 4884 Views
Last post by Amk20155
- 279 Views
Last post by volvolugnut
- 1101 Views
- 4783 Views
Last post by ronkimes
