Any recommendations? I'm looking for something that doesn't bite into the hoses ideally...
This is for my '99 V70 XC 2.4T AWD
Recommendations for great clamps for silicone radiator hoses
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
There's a recent thread where I tried to drum up support for a group buy of either ABA or oOettinger clamps...
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
I did a lot of coolant hoses on my last wagon with screw clamps, decent quality ones too, and was topping off coolant due to small leaks at the clamping points for the rest of the life of that car. So I’m planning on switching to oetiker clamps when I replace them on my v70 in the coming months.abscate wrote: 21 Jan 2018, 02:33 There's a recent thread where I tried to drum up support for a group buy of either ABA or oOettinger clamps...
I would have already started on some other hoses but the car just cost me a few hundred chasing a rear braking issue so I put that order off probably until next month.
Here’s what I’m gonna order:
https://www.amazon.com/gp/aw/d/B00QK3V4 ... 0DER&psc=1
(Probably mostly too small for the main coolant hoses).
https://www.amazon.com/gp/aw/d/B017V1AU ... DB5F&psc=1 (Good set for coolant hoses I think but you might need a few larger ones I haven’t sized out yet)
https://www.amazon.com/gp/aw/d/B01IBA4S ... 0DER&psc=1
(Tool that allows you two angles at which to pinch off the clamps)
A cheaper way would be to look for sets that come with some larger clamps and a tool, usually the tool in the sets won’t allow you to come in from the side though.
If you go that way I’d be eager to hear your thoughts, I’ve got the PS hoses at the Resevoir to do first as they’re weeping ever since I replaced the Resevoir and used lower quality screw clamps, then I’ll be moving to the coolant hoses. They are getting a little too soft and swollen for comfort.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
- Has thanked: 2199 times
Not sure you would use all of those clamps, but the tool is good as it can crimp straight on and on the side.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Constant torque clamps are used in many applications with silicone hoses. Intercooler hoses on commercial trucks running 25# or more boost use those. you can find them on amazon or ebay if you search "constant torque clamps". Breeze brand are good.
- wizechatmgr
Thanks Jimmy, when the lines come in I will stop over and see my aunt-inlaw (is that a thing?) at Mack. If that doesn't pan out, I'll stop by my brother inlaw's work at Cummins.
Why I don't think of these things I may never know...
- 38 Replies
- 13814 Views
Last post by 454cid
- 26 Replies
- 7073 Views
- 34 Replies
- 10994 Views
Last post by theWIFES_S70
- 1884 Views
Last post by B234R
- 13 Replies
- 1719 Views
Last post by vtl
