So with the opportunity to get into a few things without needing it for work in the AM I spent a lot of time around the car today.
And in true fashion with this car it rewards me with multiple new leaks.
Possible Camshaft Seal Leaks:
1) it’s continuously pouring oil out around the coils underneath the plastic cover. The rear camshaft wheel on the timing belt that is closest to the windshield is damp whereas the other rear cam wheel is bone dry, is this enough evidence that the seal is blown it should or should I look for some other proof?
(Edit: after some research I realize what I’m referring to here is the exhaust valve VVT cam seal)
2) I know the front cam seal is a likely culprit, I have the telltale oil dripping off the tranny. I just can’t see that area of the engine at all, are there any other signs I’ve got a front cam seal leak that I can look for?
Turbo Leaking:
Cold side of the turbo is soaking wet in oil and it’s spraying a lot of oil up into the top intercooler pipe. I realize that means it’s internals are on the way out, but as far as the cold side being covered in oil is that typically the turbo oil seal I always hear about?
It’s also leaking on the drive axle around the transfer case and the rack is leaking bad on the passenger side. I don’t have questions about those leaks for now, they just suck
Underside was dry as a bone 10K miles ago.
Man this car is killing me.
