Tsb info for a 1998 motronic 4.4 elevation flash
I've done a few searches and have come up empty. I'm looking for info on that tsb for the 1998 turbo cars on reflashing the ECM. A local dealer still has a functioning compaq laptop to do that flash. I just want to see if anyone has a copy or link to that tsb so I can check if my car falls with in the VIN range. Thanks
- Has thanked: 311 times
- Been thanked: 817 times
Flashing the ECU is very easy these days, you can do it yourself with investment of a little time and common, cheap hardware. However I've never heard of an "elevation flash." Curious to see if anyone else has.
- Been thanked: 4064 times
Flash for altitude? Don’t most every Systems monitor mass flow and pressure directly?
- RickHaleParker
- Been thanked: 977 times
There is a altitude sensor, the ECM uses it to adjust boost and fuel mixture for air density.
On your '99 V70 it is located on the same mounding bracket as the outside temperature sensor.
The altitude sensor on my '98 C70 get wanky ~ 0°F makes it hard to start the engine.
Active
Past
Past
Yes, Motronic 4.4 monitors both.
Im noddling on this a bit. If the MAF really measures mass of air then the pressure should not really matter. Of course, it doesn't actually weigh the air, I believe ours are hotwire type sensors that measure cooling or heat transfer . That property would be a function of the density of the air flow, but it might intrinsically correct for pressure change..
Hmmm
Hmmm
- RickHaleParker
Try solving this problem then maybe your get it.
The MAF is 12.5 grams per second. How much oxygen is there in one liter of air?
Active
Past
Past
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Air or oxygen is not measuring in liters....it measures in grams or kilograms.
Am i missing something here?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
Air and Oxygen can be measured by Weight, Volume, Mass or Moles. Engine displacement is measured by volume.
Active
Past
Past
