2004 s40 1.9t
1996 - 2004 S40
1996 - 2004 V40
raz19111
Year and Model: 2004 s40 1.9t
2004 s40 1.9t
Post by raz19111 »
I'm new to the forum, and new to Volvos. I like my s40 1.9 turbo, but i'm having a problem with the heat/defrost fan control. the fan goes on and off when it feels like. I replaced the transistor (mj802) but am still having the same problem. any help would be appreciated
raz19111
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
It's a common problem with no apparent easy or inexpensive solution.
Ive also tried changing the resistor, cleaning the sensor.
Some people have suggested replacing the "pots" on the ECC (Electronic Climate Control) but I haven't come across many convincing posts that make it a "sure thing".
There is a place that used to sell reconditioned ECC units for a few hundred bucks.
I think it was XMODEX.
Edit: It looks like they still repair them. You may want to contact them to see if it's the cure for your symptoms.
https://xemodex.com/us/product/climate- ... 244-10-20/
Post back if it works for you.
'84 Prelude
'06 MPV
'13 Ford Focus SE
raz19111
Post by raz19111 »
thanks for the info. only bad thing about the car
alschnertz
It's pretty annoying. Mine will usually calm down after about 20-30 minutes.
Fortunately I don't need to use the blower very often.
'84 Prelude
'06 MPV
'13 Ford Focus SE
broadusc
Year and Model: 2000 V40
Post by broadusc »
I had the same problem and replaced the transistor and even the climate control unit. Ultimately, it was the blower motor, which was super easy to replace. I got a cheaper motor than the original heavy Bosch. It's a little louder, but it beats not having heat and defrosting in the winter.
