740 Engine low on power
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Guffy
Year and Model: 89 740 turbo
Post by Guffy »
Hello I just bought a Volvo 740 the car runs and idles fine but the moment I put it into gear and put the engine or load it has no power it tries to stall but won't stall I've drained the fuel tank since there was rotten fuel in it and put fresh fuel in
I'm thinking the fuel pump might be bad and the filter should be replaced
I'm new to owning a volvo. So any help would be appreciated
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
I had a 1989 740 GLT from new until late 1994. Every time the car had running issues it always was the airflow sensor. Volvo replaced it many times as I recall. I think it was a problem spot on those cars. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Check cam timing?
85 GLH, 367 whp
00 Insight, 72 mpg
June
Post by June »
In thinking further with hazy recollection the car would start, than die when in gear. I vaguely recall having to unplug the sensor to drive it in for service. While plugged in car as not driveable but would start and idle. June
My Volvo cars owned
1996 960 ordered
Guffy
Post by Guffy »
I'll check all the suggestions. I should also give more info on the car it's a 89 wagon. I Did drive it home and it would randomly get power and take off but 90 % of the time it didint like driving
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
740 GL?
740 TURBO?
740 GLE-16 valve?
Engine? ... B230F LH 2.4, B230F Regina, B230F, B230FT.
Run the VIN number through the Volvo Tech VIN decoder and see what you can find out about the car.
Guffy
Post by Guffy »
It's a 740 turbo
lummert
Year and Model: 760 1988
Post by lummert »
Boost leak?
1988 Volvo 760 Turbo Wagon
