2001 S80 T6 and have had a P0455 CEL code for a long while and been lazy in fixing it. There is also a pretty good oil leak that seems to originate above the turbos. I cleaned the underside of the oil pan and up the back side of the engine and any hoses and lines then did some errands to check where fresh oil was running from. Lost track up above the turbos.
Oil leak related to evap error code? What research I did about where to start with fixing the evap code was disheartening since I read that there could be any number of places that hold the problem. So I have just been keeping up with adding oil... (spent way more in the long run, I know. My laziness is level 70) mostly.
I have another thread going about a misfire and cvvt error codes so created this one to track and keep seperate. Also in case this might be the cause.
P0455 evap leak code w/ oil leak
- 945 Views
Last post by bmdubya1198
- 1355 Views
Last post by Miltown
- 2287 Views
Last post by 800artfreed
- 2779 Views
- 20 Replies
- 1471 Views
Last post by VolvoOwl98
