2007 S60 2.5T Occupant Weight Sensor
brianbe
Year and Model: 2007 Volvo S60 2.5T
Post by brianbe »
Hello, I have a 2007 S60 2.5T AWD. The car was in an accident.
Hit a deer. Steering wheel bag blew. All three rear seat belt tensioners blew. Driver's seat belt tensioner blew.
All said components have been replaced, SRS module was reset, and all relative codes cleared and stayed gone.
Two SRS codes remain, however, and they return immediately after being cleared by a $6000 Snap On scanner.
0259 and 0261 - OCCUPANT WEIGHT SENSOR SIGNAL MISSING OR DISABLED
Please be patient here, as I am well aware that there are numerous other posts regarding these exact codes. My following questions are very specific and have not been answered in any post I have found. Let me clarify that all connections have been checked and there are no kinks in any hoses or harnesses.
I disconnected the battery before I did any troubleshooting. Using an external 5 volt power supply, I connected my voltmeter to the seat bladder pressure transducer (+5v, GND and signal). Without anything on the seat I read 4.19 VDC, with 40 pounds, I read 3.35 VDC and with 80 pounds, I read 2.83 VDC. Are these readings within the permissive range?
Question One: Even though no front passenger side airbag was deployed, is it possible that the small black OWS module (part number 30767440) located under the seat was affected and therefore needs to be replaced or reset? The sensors pertaining to that seat are the 2-wire inboard belt sensor, 3-wire outboard belt sensor, bladder pressure transducer and module 30767440.
Question Two: If the answer to Question One is YES, then will replacing that module, calibrating the OWS and clearing the two codes ( 0259 + 0261) take care of my problem?
Of course any and all suggestions and advice will be appreciated.
Thanks to all.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Possibly
You can go used if you can find one but it has to be year specific (been there, done that)
Was VIDA used?
I would run it on VIDA first to get a more specific answer and/or the factory way to fix this. It may just need to be mated with your new other sensors and the car
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Can't answer but I think replacing means removing the bottom foam and replacing the whole pressure 'bag' - I would only had this replaced by a specialism in car wrecks, as it's attached in a certain way.
brianbe
Post by brianbe »
JRL wrote: 03 May 2018, 12:17 Possibly
Was VIDA used?
"I believe it was an $8000.00 Autel nit my mechanic has to get the codes."
Has thanked: 1609 times
Been thanked: 4063 times
You need VIDA to reset the pad and recalibrate it after a replacement.
I would open the seat up to check for leaks, the whole system holds 500g silicone and SRS will trip if more than 100g or do leaks out
Vida will Tell You where the fault is and give you a one click recalibration of the control module. Vida says you have to input its serial number too, so there probably isn’t a way around this
Alternatively about a $2000 bill at Volvo or $1500 at a good indie
brianbe
Post by brianbe »
I have opened the seat and checked for leaks or puddles of silicone and none could be found. I disconnected the battery and used a seperate 5 Volt power supply (actyal voltage was 5.19 volts) to provide power and ground to the air bladder pressure transducer (the sensor that is connected to the bladder hose filled with silicone. Using my voltmeter, I read 4.19 volts with an empty seat, 3.35 volts with 40 pounds and 2.83 with 80 pounds on the seat. So, there is a change in value in volts based on different weights being placed on the seat.
An Autel MaxiSys Pro unit was used to come up with codes 0259 & 0261. Recalibration was tried and the message on the Autel said faults cleared however the SRS lights remained on. The Autel tool did not ask for the V.I.N, perhaps that is the difference between The Autel tool and VIDA (I don't know what VIDA stands for.)I suppose it is Volvo's proprietary diagnostic tool. Has anyone used a scanner that will reset the Volvo codes? I hear that Snap-on makes some high end diagnostic units.Thanks for all of the suggestions. Perhaps it is time for me to go to the dealer and be prepared to drop a pile of cash.
My Autel 800 series clears SRS codes, and it cleared a BCM code recently too.
Are you near me in ALB NY area? We could give it a shot if you/me are driving by, I have a summer place in Point du Fer which I think is a trebuchet throw away
brianbe
Post by brianbe »
We are 17 miles apart. I live across the pond from you. I look at the north end of Isle LaMotte. When do you expect to come up?
Brian
Ive got two trips up scheduled for MTL in the next month and have to check on the cabin and boat (shared with friend) so will PM you my coordinates.
brianbe
Post by brianbe »
Thank you!
