98 Volvo V70XC white/ charcoal for sale, very clean Topic is solved
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
For sale is my 98’ XC in white/ charcoal with 166k+ miles on it.
The car is very presentable inside and out, with shiny paint and a nice and clean interior.
I purchased it in the summer of 2012 from JRL with 107k on it. For what it’s worth, here is the original ad sans photos:
viewtopic.php?f=6&t=48128
As to be expected, the car was very clean to begin with, and I tried my best to preserve it, or make it even better in some respects.
It drives and shifts as it should with the AWD fully intact. At this point, pretty much everything that can fail on these cars has been addressed. No CEL or any codes, and even the SAS pump is still working fine.
The engine has been replaced with a used one from Erie Volvo at 132k (had 105k when installed). This was due to a water pump failure at highway speed, and it destroyed the head.
The engine is completely original and it uses next to no oil and doesn’t smoke at all.
The tranny is original to the car and never gave me a problem.
All the major AWD components have been replaced with new Volvo OEM parts, except for the prop shaft, which is rebuilt.
The suspension has been refreshed with new struts upfront and new Nivomats in the rear.
The brakes have been done recently with Zimmermann rotors and Akebono pads.
Also, the parking brake has been completely rebuilt with new OEM cables, shoes and hardware.
The A/C is still blowing nice and cold, and the heater works fine.
A while ago I rebuilt the front C/V axles with new boots and fresh grease. Again, only OEM parts were used for this.
The steering rack developed a small leak over the years, but adding some ATP 205 solved that problem.
The car comes with a set of Berber mats and a Weathertech cargo liner.
I have all the repair and maintenance records for the 6 years I have owned it if anyone is interested. I also have the receipts of the work Jim has done prior to delivery to me (timing belt, evaporator, heater core, rebuilt SAS pump, tranny flush, new PCV system etc.)
Oil changes were done every 3500 miles give or take with conventional oil and always with Mann filters. I did a couple of drain and fills of the tranny fluid about 2 years ago and it still looks good.
The body has no rust, but the exhaust system and some suspension components have some surface rust as to be expected for a 20 year old car.
The car has been mildly modified with the following:
  • 302mm front brake conversion with Zimmermann slotted rotors
  • Rear wing
  • XC banner and emblem delete on tailgate
  • Depo Jewel headlights
  • “R” style door panels
  • “R” instrument cluster with chrome rings for the gauges and matching mileage
  • Meteor rims with Pirelli P7 all season tires in 215/55/16 which are just like new, NO curb rash, not even a scratch on any of them
  • Eurosport dual exhaust
  • K&N Air filter
  • Aftermarket Kenwood stereo is installed right now, but the original stereo comes with the car
Below is a more detailed history of the major repairs of the XC, keep in mind there are quite a few smaller parts like light bulbs, door check strap, tail gate shocks etc that are not listed here, otherwise the list would just be too long and who wants to read that much anyway.
04/2018... @ miles: 166,342 - Torque tube bushing replaced.
01/2018... @ miles: 166,142 - Front left wheel bearing replaced.
12/2017... @ miles: 164,605 - New OEM radiator installed. New OEM lower trans. Cooler line installed. Rebuilt Bosch starter installed.
09/2017... @ miles: 164,600 - Rebuilt Bosch alternator starter installed.
10/2017... @ miles: 164,551 - Fuel line from fuel filter to fuel pump replaced. Fuel filter replaced.
03/2017, New Interstate Battery installed.
12/2016... @ miles: 163,150 - New OEM viscous coupler installed. New throttle cable installed.
10/2016, Removed front C/V axles, cleaned and re- packed with new grease. New OEM axle boots installed.
09/2016... @ miles: 162,400 - New front and rear brakes installed. Zimmermann 302mm front slotted rotors with Akebono Pads. New OEM front caliper brackets. Zimmermann rear rotors with Akebono Pads. All new parking brake parts installed with OEM cables, OEM pads and new hardware.
06/2016... @ miles: 158,600 - New Lemfoerder sway bar end links installed. New Mann cabin filter installed.
10/2015... @ miles: 159,782 - Used viscous coupler from Erie Volvo installed (this failed shortly after install)
03/2015... @ miles: 154,920 - New serpentine belt installed. New fuel pump relay installed.
12/2015... @ miles: 150,855 - 4-wheel alignment done at Volvo dealer.
11/2015... @ miles: 149,300 - New OEM radiator expansion tank, Cap, Level sensor, related hoses and thermostat installed. Coolant replaced. Oil cooler lines replaced with OEM along with new seals.
09/2014... @ miles: 145,200 - Front right control arm replaced with Meyle HD part. Transmission drain and fill
08/2014... @ miles: 143,865 - Rebuilt front calipers installed, brake fluid replaced. Transmission drain and fill
08/2014... @ miles: 143,300 - Front left control arm replaced with Meyle HD part. EVAP system rebuilt with new charcoal canister, new purge valve, new shut off valve and new silicone hoses. Transmission drain and fill.
08/2014... @ miles: 142,700 - Both rear shocks replaced with OEM Nivomats.
05/2014... @ miles: 139,850 - Full tune up with new Volvo plugs, OEM cap and rotor and Bougicord cables.
03/2014... @ miles: 135,850 - New OEM angle gear installed
01/2014... @ miles: 132,027 - Engine replaced with a used one from Erie Volvo with 105k and 1 year warranty.Timing belt kit with water pump installed with blue box parts.
12/2013... @ miles: 131,300 - 4-wheel alignment at Volvo dealer. Rebuilt prop shaft from Colorado Driveshaft Installed. New Sachs front struts with all new hardware installed.
12/2013... @ miles: 130,000 - K&N air filter installed.
07/2013... @ miles: 123,000 - New front brakes installed. New Mann cabin filter installed.Front right and rear left door lock actuator replaced with new Volvo parts.
04/2013... @ miles: 117,233 - Angle gear removed and seals replaced (this failed shortly after install)
I tried to list things to the best of my knowledge, if you have any questions, just ask.
My indie mechanic did most of the bigger stuff, but I did quite a bit of work myself.
So, what’s wrong with it? Not much:
  • The only remote I have for the car quit working the other day. I installed a new battery, but it still won’t work.
  • The tailgate is developing a little rattle again.
  • I lost the little flaps in front of the rear wheels.
  • Driver side fog light lens has a crack, but there is no moisture inside, possibly because they are covered with Laminex
  • The new viscous coupler makes a slight whiny noise which usually disappears after a few miles of driving. This does not have an effect on drivability and hasn’t bothered me much.
Asking price is $5600. No low ball offers accepted.
PM or text me if your interested, twozerothree, fiveonetwo, threefivesixnine
Thanks for looking,
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
Damn, that is a beautiful thing! Wish I had another $3k. :)
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Beautiful. If I needed a new car right now, I'd buy this.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Yep 👍 I’m with them ^
Also -> Amazon link
850 LPT
Post by 850 LPT »
Thanks guys :D
A big thank you to Matt who helped me with some major formatting problems today!
FlyingVolvo
850 LPT wrote: 14 May 2018, 17:34 Thanks guys :D
Question for you. I see you have the EST dual exhaust. Is that the Mototec "Touring" exhaust? Am I correct in assuming you still have the cat, and so cat-back is just the dual exhaust?
If so, how's the sound? Any droning on the highway?
This one: https://www.eurosporttuning.com/mototec ... odels.html
Thanks! I can't find many reviews of this product, and even fewer that have the same car as me with no other big mods like downpipes, etc.
2023 V60 T8 PE
850 LPT
Post by 850 LPT »
Yes, that's the one I have, I haven't seen it described as Mototec before. The XC still has the original cat just like you suspected.
It sounds really nice, there is absolutely no droning at any speed.
The quality is so so but for that it's fairly cheap. My indie had a bit of hard time with fitting the pieces together and aligning everything right.
Has thanked: 1836 times
Been thanked: 1709 times
Save your money and don't buy that muffler system it is junk. P.O. of my 'R' fitted this and it holed really quickly on the mufflers. See if you can find one made in real stainless steel T304. The stuff they used is no better than mild steel.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Why are your door panels in such great shape? Why isn't the glue failing and causing the skin to lift off and look like someone inflated the door panel?
Are they replacements? Did you repair them? They look perfect. Whole thing looks perfect. I'm jealous.
I'm also glad I don't need a new car because I'd be talking my way into a higher price not lower. :-)
Andy
850 LPT
Post by 850 LPT »
amblerman wrote: 14 May 2018, 20:16 Why are your door panels in such great shape? Why isn't the glue failing and causing the skin to lift off and look like someone inflated the door panel?
Andy
Hi Andy, thanks :)
The door panels are from a V70R. These door panels have leather inserts that are not prone to the glue failing problem. The regular panels that came on these cars can be repaired though. I have seen quite a few posts here were people used all kinds of different glues to make them look like new again. But it's a labor intensive process from what I understand.
Dirk
