C30 heater-a/c problem
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Sid001
Year and Model: 2010 C30 T5 R-Design
Post by Sid001 »
Hi, I have a C30 T5 and blower for the heater and a/c is blowing very softly, you can feel if your hand is up by the vent but the car does not get hot/cold.
My wife also has a C30 and her fan blows at much higher speeds.
Any suggestions, Volvo said probably not the motor itself but another component that might control regulate the motor speeds?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Assuming it's a 2010, if you turn the blower to the max speed, do you hear lots of venting behind the dash?
If not, it may look like this topic https://www.volvoforums.org.uk/showthread.php?t=200011
These blowers commonly fail on P3 cars and it's not pretty. The parts looks like this and it takes a special Volvo tool to remove it from there
https://www.fcpeuro.com/products/volvo- ... 0-31390437
Maybe also check the knob for proper working.
Sid001
Post by Sid001 »
yeah quite a bit, sounds like plenty of air but nothing or very little coming out vents
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Sid001 wrote: 15 May 2018, 03:50 yeah quite a bit, sounds like plenty of air but nothing or very little coming out vents
Could be something blocking the recirculation vent, like a piece of paper or napkins that was inside glove box. I'm not 100% sure about the C30 but on the XC70 behind glove box is location of cabin filtration, ventilation and blower motor. Look in the area.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
oragex
Post by oragex »
As above, if the fan makes loud noise at max but little air coming out, I'd look in order at the cabin filter, ducts to the blower blocked by leaves etc, then inner climate doors perhaps not opening. Plugging it on Vida should indicate if the actuators are not operating the doors properly. Sometimes as little as a calibration may fix the issue. The swirl arms on the actuators may also be broken.
Sid001
Post by Sid001 »
Thanks, will check this weekend and advise.
