Hello,
While driving around 50-65 mph the car starts vibrating. The vibration is not so much in the steering wheel, but you can definitely feel it. When the car is on the highway and the vibrations starts, it will stop when you release the gas.
The front tires have recently been replaced and balanced.
Note: a few weeks ago I hit a 2"x4" wooden beam on the road at night at 50 mpg, and the swaybar link on the passenger side was broke in half. I already replaced both swaybars. Wonder what else might be damaged by this big hit.
2004 S80 - Vibration during driving
- June
- Has thanked: 523 times
- Been thanked: 261 times
You likely have a bad axle. I had the same problem with my car but I thought it had a misfire. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Two questions:
1) Is there an easy way to determine if it is the right or left axle?
2) I see that the Volvo brand axles are about $600 and aftermarket axles around $100-$130. That is a huge difference.
Any recommendation for a good after market axle, or a brand to really avoid buying?
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
2004 S80
- June
I had my dealership replace mine. $1000 per side or so. Does come with lifetime parts and labor guarantee. I read on here aftermarket axle is a waste of time. Before I spent $600 and did it myself, I would pay Volvo and get the warranty. Yes they honor their warranty from my experience with my axles without question. When my car vibrated it was the driver side inside joint. Volvo replaced both axles under warranty though the driver side was my cars trouble. They wanted to be thorough. Bad engine mounts caused the abnormal wear. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It is very easy to check the axles on the car - just make sure to jack and support the car safely on jackstands, never only on the hydraulic jack or worse on the spare jack. Then grab the axles near the cv joints and give them a good shake . Also look for cracked dust boots over the cv joints www.youtube.com/watch?v=EJQkFPYjh5E
May as well look at the control arms, with the car on ground and front wheels at full lock look on each side at the rear bushing for cracks.
Use only quality parts for the control arm, genuine is the best, Meyle HD and Lemforder may be good for a few years or more
For the axles, I would definitely go only with recently replaced used genuine ones, aftermarket/rebuild ones are often times terrible and cause vibrations
virtualking
- Year and Model: XC60
It may be alignment or axle problem you should make wheel alignment and it would work properly
- SuperHerman
- Been thanked: 207 times
wheel bearing?
During the last few days the vibration is almost gone. Almost looks like something got back in place, whatever it was. I'm sure it will come back.
I do know the boots are worn out on the transmission side of both axles, so those need to be replaced soon.
Did anybody ever do a rebuild of the axles and CV joint?
2004 S80
2004 S80
- SuperHerman
If your boots are compromised debris will get into the joint and destroy it.
Changing CV boots and cleaning and regreasing is like on any other car. An easy but messy job. Should be plenty of write ups.
Hello, it has been a few months now, because I had to fix another electrical problem first.
During driving the vibration is mainly in the chassis, and I'm not feeling much vibration via the steering wheel.
So this makes think that it not so much the axles but more the shocks.
Is there an easy way to check the shocks, without taking them out?
2004 S80
2004 S80
- 956 Views
Last post by Vovo_merz
- 6471 Views
Last post by MadeInJapan
- 1881 Views
Last post by MoVolvos
- 2464 Views
Last post by shiloh51933
- 1088 Views
Last post by Friedtrout
