is there any procedure showing how to replace a horn on 2004 XC90? I removed the right head light assembly and I was able to see it but I couldn't get to the connect adapter itself as there is a bar obstructing my view...
I checked fuse # 9 and its good, when I open the hood and try to honk I hear a ticking sound every time i press the horn which tells me it might be the horn itself.
let me know. Thanks
Horn Replacement Procedure
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
In Vida it says to:
- remove the right hand headlamp
- remove one of the horns from the bracket to facilitate removal and installation
- slacken the screw for the bracket (probably 10mm, is an M6)
- angle out the horn and bracket
- disconnect the connector
There is no illustration in my version, but that's what it says.
There are two horns, though, so it may be a wiring or ground issue.
