i can somebody help i have just had my cd player decoded and a new code fitted but i dont have a manual so i dont know how to enter the new code to get it to work.
please help thanks.
Wayne&Lisa
entering cd player code
Wayne&Lisa
- Year and Model:
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
What model and year of car and which radio?
I have assumed it is an S/V 40 with either HU415 or HU615 radio.
To enter the code
After installation or when the set has been disconnected from power, the set displays "input CODE ****" when it is switched on. Enter the 4-digit code using the 1-20/DISC knob. Select a number for a digit by rotating the 1-20/DISC knob. And then push the knob to enter the number. Repeat the procedure for all 4 digits.
If the correct code is entered the set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "Error" is displayed. Enter the correct code. After three unsuccessful coding attempts the set will lock and remain locked for two hours. "OFF" is displayed.
During this waiting period:
the battery must be connected
the ignition key must be turned to position I >LI? the unit must be turned on Make sure the headlights are turned off to help prevent battery drain.
Enter the code again once 2 hours have elapsed.
Hope this helps.
Bill.
To enter the code
Incorrect code
Hope this helps.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Wayne&Lisa
- Year and Model:
thanks sorted now...
- 646 Views
Last post by ThommyKent
- 2185 Views
Last post by traveader
