04 XC70 Turn Signal Switch
I just started getting intermittent left turn signals and it seems to be in the column switch as I can move the lever a bit and it will make contact. Is there a good write up on changing these out? Thanks.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The stalk is fitted with one screw onto the steering column. Just remove the rubber around its base and you'll see it. Very easy to replace. Get one from the same year and it'll be fine.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I've had the same problem on both of our P2 cars. In both cases I was able to dismantle the switches, clean the internal contacts, and that got them working again. No extra parts required.
In a lot of cases the problem is the grease they use on the contacts - it hardens with old age and becomes more of a hindrance than a help. Clean them out with electronics cleaner or alcohol, scraping the contacts clean. Then apply a TINY bit of dielectric grease to the contacts and internal mechanicals.
Like all small switches, disassemble it on a towel and be careful as there may be tiny springs, etc., that will go flying. It ain't rocket science.
- 3299 Views
Last post by firstv70volvo
- 978 Views
Last post by Metallo
- 1363 Views
Last post by ggleavitt
- 14 Replies
- 2959 Views
Last post by Mike Langlois
- 1098 Views
Last post by vmaxmike
