WTB: VIN code 53 Engine for 1998 T5M PNW OREGON
lewisness
Year and Model: 1998 S70 T5 5sp, '08
Post by lewisness »
Need an engine for my son's 1998 T5M. It is the kid's first car, he paid $500 for it. We put a rack in it as well as cam seals. He learned a painful lesson about not pulling over when the low coolant light went on, hence the need for the motor. He loves the car and wants to replace the motor. Another Volvo freak is born! :)
Just thought I'd ask before hitting the junkyards.
-Jim
Present:
'98 S70 T5M
'08 XC70
‘15 Q7TDI
Past:
'95 850 Turbo
'97 850 T5
'97 850R
‘98 V70XC
'00 V70R
'02 S60 T5
'02 V70XC
“I spent half my money on gambling, alcohol and wild women. The other half I wasted.”
-WC Fields
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
How hot did he get it?
Code 53 for 1998 is the B5234T3.
The B5234T3 was a engine option in:
1997–2000 Volvo S70.
1997–2004 Volvo V70.
1998–2002 Volvo C70.
2001–2004 Volvo S60.
You probably want to stick with one that has a distributor rather then coil over plugs, for a direct swap. 1997 - 1998.
lewisness
Post by lewisness »
Thanks for this Rick, super helpful. He got it all the way hot. Like making engine oil-antifreeze mayonnaise in abundant quantities hot.
Present:
'98 S70 T5M
'08 XC70
‘15 Q7TDI
Past:
'95 850 Turbo
'97 850 T5
'97 850R
‘98 V70XC
'00 V70R
'02 S60 T5
'02 V70XC
-WC Fields
RickHaleParker
If you decide to go after a P-n-P motor. Pull one out of a wrecked car, you know that engine was running. If you have one of them jump start battery packs, take it with you. You can hook it to the car and read the mileage and if it has nonvolatile memory, you can pull the DCTs. Gives you some clues to the health of the engine.
Has thanked: 1846 times
Been thanked: 1710 times
As you are on the 'Left' coast you could try vandsautodismatlers in Sacramento, CA for and engine, or even Chapman motors on Vancouver Island in Canada. The Chapman Motors guys usually supply good stuff and you may get a good deal with the exchange rate.
lewisness
Post by lewisness »
Thank you Neil. I've been scouring car-part.com for one. I'll check Chapman out.
Present:
'98 S70 T5M
'08 XC70
‘15 Q7TDI
Past:
'95 850 Turbo
'97 850 T5
'97 850R
‘98 V70XC
'00 V70R
'02 S60 T5
'02 V70XC
-WC Fields
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
You're overthinking it a bit in restricting yourself to a VIN 53 engine. The VIN 57 (96 HPT) and VIN 58 (96-97 R) or even B5234T6 (98 R) engines are the same as well. You want any 2.3 liter high pressure turbo engine from a 96, 97 or 98, these are all the same. You could actually use any 95 or 94 turbo as well but there may be a few small quirks to deal with, stick to 96-98 HPT for the straight plug and play.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
