1991 740 Turbo Instrument Panel Swap
Hello, my 740 IP odometer failed and I installed a working 940 IP. All works fine now, except for the fuel gauge, shows reserve light on and no fuel regardless of actual fuel level. Online info indicates that volvo may have changed the resistance requirements after 1991, so I am looking for a fix, if any. Thank you.
- RickHaleParker
- Been thanked: 979 times
Check the solder joints on the back of the 940 IP. The ones to the fuel gauge are known to crack. Some times a solder reflow is all it takes to get the fuel gauge working.
Active
Past
Past
- RickHaleParker
You question is tipping me off, you don't have soldering experience. This should be done by somebody that knows how to solder, if it done wrong one can burn up the printed circuit.
Active
Past
Past
Yes, not much soldering experience here. Also, as stated before there may be a resistance issue from the sender so i am looking for a later (posy '92) fuel sender to put in the tank and see if that fixes this. Thx again for the advice.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
I have a 1993-940, and dash's fuel reading always shows full...vehicle came that way.mcclusk wrote: 02 Aug 2018, 06:46Also, as stated before there may be a resistance issue from the sender...
I assume fuel-tank sender was the issue....as in someone screwed the pooch when replacing fuel pump. But, since vehicle runs fine, I use odometer.
Vehicle has over 1/4 million miles on odometer, so I assume fuel pump has been replaced once. It might be the dash unit, or fuel-tank unit.
Ohm/Volt meter is your friend....
I've driven for years with defective fuel-gauges....its a convenience....only once did I run out of fuel, and I was headed to get tank filled,
- RickHaleParker
Anybody that really knows how to solder can inspect the solder joints and spot defective solder joints. Is there an electronics shop class at the school?
Active
Past
Past
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I've been using a VDO oil pressure gauge that is just left lying on the console of my 88 765 as a fuel gauge for several years. Never tried to figure out the problem with the gauge. For certain the problem isn't fuel sending unit related.
1988 Volvo 760 Turbo Wagon
- 1566 Views
Last post by Teddy1975
- 1066 Views
Last post by 93Regina
- 1466 Views
Last post by volvolugnut
- 9713 Views
Last post by zoli440
- 985 Views
Last post by j-dawg
