Swivel needed?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Swivel needed?
Post by Mr. Detail »
Morning guys;
I made an attempt to remove my existing upper left side tail light assembly but my straight socket with or without the extension just does not cut it. I thought this would be easy but it seems I need some additional tool(s). Is a "swivel" adapter what I need to loosen those two 10mm nuts?
Has thanked: 1505 times
Been thanked: 3818 times
Also called a wobble or universal joint.
Tape the socket and swivel to the extension so they don’t drop into the abyss of the tailgate, a couple of wraps
Mr. Detail
Thx much abscate! Will do.
Archer
Year and Model: 2002 V70/S60 T5
Been thanked: 5 times
Post by Archer »
Should not need a swivel/wobble socket for the tail light assemblies, just a deep 10mm socket. Have a telescoping magnet handy, too.
kranz
Year and Model: '98 V70 NA stick
Been thanked: 7 times
Post by kranz »
Archer wrote: 08 Aug 2018, 13:14 Should not need a swivel/wobble socket for the tail light assemblies, just a deep 10mm socket. Have a telescoping magnet handy, too.
I echo the use of the 10mm deep socket. Also put a bit of grease around the edge of the socket so the nut sticks to the socket when it comes off rather than falling into the abyss.
Les is more.
