1994 850 NA wandering idle Topic is solved
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
I have '94 850 NA with wandering idle and erratic hard start. I did the complete pvc job, cleaned TB, MAF, IAC, fuel injectors w/ new prongs, new thermostat, ECT sensor, and full tune-up. Idles wanders from 750-100 rpm.
Also cleaned egr valve and intake manifold. When I turn key on I can hear fuel pump. The car will always eventually start, buts seems to load up until I rev it a couple of time. Any ideas would be greatly appreciated. Fuel pump or relay possibly? Thanks much, great site!
Has thanked: 2197 times
Been thanked: 1851 times
Have you checked the fuel pump pressure? It should be around 43psi.
What brand of parts have you used? The reason is these cars are very particular on the brands they like. The ECT has to be OE or Vernet to work. Also check the wiring to the ECT where the plug is on the power steering pump. It often gets crusty and fragile with age. Also check the wiring on the relays on the top of the radiator for the same issues.
GlennG2759
PCV kit from FCP, ECT from Intermotor, Volvo tuneup parts, will check fuel pressure at rail. If it low that would mean fuel pump correct? This is a project car I recently purchased and has approx 172,000 miles on it. I have no error codes (1-1-1) on A2 & A6 diagnostic ports. Thanks for you input, Glenn G.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
GlennG2759 wrote: 14 Aug 2018, 22:55 ...ECT from Intermotor...
That's a BIG problem.
The only way to go with is OE Volvo or at least Vernet.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
GlennG2759
After rechecking all my vacuum lines, I pulled one off fuel pressure regulator and fuel came out. That no good ! Replaced regulator low and behold smooth idle. PROBLEM SOLVED. I appreciate your input. Thanks
misha
Post by misha »
You are on borrowed time with Intermotor ECT.
All sensors or modules from that brand are out of spec from the factory.
Your call.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
GlennG2759
OE ECT on order. Rear control arm links are next OE's very expensive any others recommended. Thanks
misha
Post by misha »
What happened with your old ECT?
I never heard that one failed yet....mine is still original.
The problem is in the connector pins and it's wiring.
If your old one is original....you can put it back.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
GlennG2759
I guess it hasn't but wires were in pretty bad shape. I thought it pretty cool that you easily take the connector wire housing apart so you could slip a box end wrench on the sensor to tighten. I still have it will try to repair wires in free time.
Ben850
Been thanked: 7 times
Post by Ben850 »
Clean your MAF sensor completely (Bosch only). Check vacuum leaks at the manifold, valve body...
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
