Discovered that my car would not start because the green wire with the spade connector had it's plastic shell break apart and isn't grabbing the terminal. The green wire's location is in a pretty tight spot and the wire is short. Any suggestions on what's the easiest way to fix this without having to remove the starter?
Thanks!
Starter - broken spade connector
- Year and Model: Many Volvos
- Been thanked: 76 times
You can splice a piece in but even that will be tough without moving some stuff. When I splice wires, particularly in that area where they are exposed, I solder them and heat shrink over the joint.
If this is a N/A you might be able to get in there with a soldering iron but the intercooler on a turbo takes up so much space that I doubt that you can physically get to it without removing the intake manifold or the intercooler.
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
Can you get your hand in there to remove wire? I haven’t worked in this area yet so I don’t know the layout. If you can disconnect the wire, you should be able to make a new longer wire and put it back in there. You could splice new wire into harness at a place that is more accessible.
- 2020 Views
Last post by jonesg
- 2348 Views
Last post by Centex Swede
- 6551 Views
Last post by BigSpud
- 2268 Views
Last post by 850oldschool
- 137 Views
Last post by misha
