Turn Signal stalk?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
I have a question for anyone that might venture a solution to a seemingly bad electrical connection for my turn signal stalk. Almost every time I pull down or push up the run signal stalk, there is no immediate blinking of my turn signal lamp. I have to jam it up or down and pretty soon I want to just snap it off. Must I replace the present stalk?
Mr. Detail
So Mr. Rattnalle, is the problem then the connection itself within the stalk? Just want to understand.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The stalk is a contained unit with the mechanics and the electronics connected to the stalk. It's only got a a few pins connecting it to the car. So what you describe which sounds like the moving parts not getting proper contact will very likely be within the stalk mechanism.Mr. Detail wrote: 07 Sep 2018, 09:45 So Mr. Rattnalle, is the problem then the connection itself within the stalk? Just want to understand.
You could also remove the stalk and work with it on a table comfortably if you want to. But I'm not sure I would bother personally unless a replacement isn't convenient to get.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Try removing it, you can also open it where the printed board and the moving mechanism are if you like investigating things, it's not too difficult. I do not know where the problem is, but these stalks do go bad once in a while. As above, replacing with a used one from the junk yard shouldn't be that expensive www.youtube.com/watch?v=gCSbTSj1THI
Mr. Detail
Thanks guys! I don't have that much time these days, so I will pull a junk yard one and hope for the best.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
On both of our P2 cars I’ve popped the switches open and cleaned the inured. Much quicker and cheaper than a trip to the junk yard which would possibly would have gotten me one in the same condition.
Durenol
- Year and Model: Volvo 2007
- Has thanked: 2 times
- Been thanked: 4 times
I have a similar problem with my turn stalk, it engages blinking fine but often randomly disengages early or for no reason (often when turning the wheel or going over bumps).
1) How much do replacement stalks cost typically? Can you still get new ones or only used?
2) For people who have done do, how hard is it to just disassemble the stalk unit and clean it? Are they glued together or something stupid?
chrism
Last I saw they’re still available new from the dealer for around $60-ish.
Not glued together. Easily opened up. As I recall you only need to unscrew the circuit board piece.
- 13 Replies
- 4063 Views
Last post by Vova585
- 1279 Views
Last post by Wilfredo
- 2151 Views
- 1540 Views
Last post by volvolugnut
- 440 Views
Last post by chrism
