Coolant line banjo bolt washer
Hi, recently I had to repair a coolant line at the back of the block. It runs into a banjo bolt at back of the block drivers side below head. I lost the washer where can I get one. Volvo wanted 209.95 for the whole line. Hence the repair of line. Thanks in advance for any help.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I suspect you're referring to what's known as a "crush washer".
They're usually made of a soft material like copper or aluminum.
Don't know the size, but it should be pretty easy to find one.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
Actually, a crush washer is designed to be used just once, so whether you dropped it or not, it should be replaced.
However, I've been known to reuse them after truing them on a flat file.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 638 Views
Last post by jonesg
- 933 Views
Last post by MoVolvos
- 952 Views
Last post by DavidE7
- 1213 Views
Last post by oragex
- 2035 Views
Last post by precopster
