Hello!! I am new here.
I just got an 850 turbo from my mother, which she bought used in July of this year.
It has 197 thousand and some change on it. My first question or I should say minor (I hope) issue is, when u start it up there is this noise, at first thought it sounds like the power steering pump, My mother took it to a guy (I will not call him a mechanic after what he did) and he told her it was the power steering pump, put a new one on and took her money. The noise is still there. The best way to describe this noise is a cross between the noise from a power steering pump low on fluid (any old school car) and the sound of a manual transmission in reverse. I had five different people listen to the offending noise and give me there opinion as to what is causing it.
Turbo
Alternator/generator
Serpentine belt
A/C compressor
The big pulley behind the p/s pump
Is any one out there familiar with this? I have some more questions but I will wait
For a response to this one first. Thanks!! This is a great place lots of info.
Unknow Noise!!! 94 850 sedan...
I have a 95 Turbo with 141k and change and it makes the same noise at startup. I haven't thought of looking into it yet because usually after the engine warms up the noise ceases. I always attributed it to the fact that the car is 11 years old and needs to warm up a bit.
I have to do a bit of detailed maintenance on the car over the next couple of months (belt replacement, hose replacement, oil trap replacement, etc. etc.).
Maybe we'll be able to shed light on the subject...
Just out of curiosity... Have you checked out the 1995 850-Series Service Manual yet? (I am going to look there now for any info regarding your issue.) If you haven't yet, download it. Even though your car is a 94 this manual will still be pertinant and can serve as a very invaluable tool in troubleshooting/solving problems. In fact, if I remember correctly there are whole reports on troubleshooting mysterious noises.
Anyway, MadeInJapan is probably THE most helpful person here or on any Volvo board and has posted this manual for all to see, so make sure to download it and don't forget to thank him!
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Does the noise stop or is it constant?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
You don't need a download link. It is the first sticky at the top of this forum. Just click on that.
My first check would be the serpentine belt to ensure it is not starting to break up.
Bill.
Bill.
Previously:
Previously:
bobsnow100
- Year and Model:
If you removed the serpentine belt and start the engine for 15 seconds and the noise is gone ,now you have narrowed down what the problem is.
- billofdurham
https://www.matthewsvolvosite.com/serpentine_belt.php
This tells you how to remove the serpentine belt and, of course, replace it. It is not a hard job, but it is awkward because of the lack of space.
If you go down this road give the belt a thorough examination for wear/cracking. If it looks at all dodgy replace it, whether or not that is the problem.
One other thing you could try before removing the belt - start the engine and pour about a quarter of a pint of water on to the belt to see if that stops the squeak. It has worked for me on other cars in the past.
Bill.
Bill.
Previously:
Previously:
CarVolvo
- Year and Model:
removing the belt is the first part of the process i would imagine.
my first choice would be to check the could be your belt tensioner or the roller/aux. pulley. Cheaper to replace than the next group of options.
Try spinning these and see what type of noise you get from them.
The other options would be your power steering, compressor if equipped with a/c or even a bad bearing on your alternator.
one of the suppliers of parts has this belt tensioner just on their hope page so i list it for reference.
look at the bottom left and you will see a diagram showing all the pulleys on your engine. (although it looks like it in reverse..is it european?)
http://www.eeuroparts.com/home.aspx
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
